5/16" Wheel spacer with stock studs?
1 Post
I just bought a set of oem y2k wheels for my bird. Instead of beating my wheel wells i decided to go with a 5/16" spacer. I know people have said that the 1/4 is fine with stock studs but I havent seen anything about 5/16" spacers. Will I be fine with these its only a little over .06" difference but I hadnt heard of anyone using these.
1 Post
thanks guys i had a newb moment fitting the wheels. I used the stock jack and when i put the wheel on in the back it rubbed. " I didnt lower the car to load the suspension and level the rear axle out" But once i lowered the car down it had 1/4 inch or more clearance between the tire and inner fender. so thanks to my adj. pan hard bar my wheels are good.
