Drag Racing Tech
How to set up and adjust Strange DA Shocks?
Old 10-31-2009, 12:03 PM
AChotrod's Avatar
Default How to set up and adjust Strange DA Shocks?
I picked up some Strange DA shocks and springs for up front. Problem is no Directions came with them. How to you adjust these? ***** dont even have numbers on them to let you know where your at?
Thanks
Mike
Old 10-31-2009, 12:32 PM
SWeiser31's Avatar
Big **** is rebound, small one is compression. With the ***** facing you, all the way left is full loose, all the way right is full tight. I would verify this by turning them all the way one direction and see if you can pull it out and push it in on your own. If you can, obviously they're full loose. That's the only thing I don't like about the strange shocks. Nothing is labeled. It's hard to feel the clicks as well.
Old 10-31-2009, 01:26 PM
AChotrod's Avatar
I know right. They could just print out some directions and things would be much simpler.
Now Should I set them up as loose as they will go?
Old 10-31-2009, 01:31 PM
SWeiser31's Avatar
I don't have any experience with adjustable front shocks, but I wouldn't think you'd want to start at full loose. I'd start somewhere "neutral" and work from there. I think there's a thread on this in this section. The drag tech mod JLWS-6 has some good info in it. I'll see if I can find it, or you can just pm him.
Old 10-31-2009, 01:34 PM
AChotrod's Avatar
Im starting with the rears at 50/50 but dont know how to set up the fronts. Thanks any info would be great!!
Quick Reply: How to set up and adjust Strange DA Shocks?
