Do i ABSOLUTLY have to drill a ABS hole?
Bought a 4channel rearend with 4.10's. I have a 3 channel. I have everything to bolt up. I have the 3 channel axels and everything. The only thing i have left is to drill a hole for the ABS sensor. If i dont drill the hole, what are the consequences of not having the ABS sensor on the 4 channel rearend other than the obvious, no ABS?
This is exactly right. The "pulse per mile" is different. It will try to work and then set a performance code. Before the code sets, it thinks the rear is locking up and it makes the ABS activate. If there was a way to drill the housing without taking it out I would do it. If I'm going to take the housing out, I'll put the correct one in it, if I can find one! (hint)
