how long has your RMVB th400 w/brake lasted on the street? (miles)
Old 11-01-2009, 12:49 AM
Restricted User
1BAD_LS1's Avatar
Default how long has your RMVB th400 w/brake lasted on the street? (miles)
I am curious to see how long the RMVB th400 w/brake lasts on the street (miles)...
I read a thread that it will only last 10-20000 miles!!!!!! That seems crazy...
I figure with a big Tranny Cooler it should last quite a while....
at 10-20000 miles i would have to rebuilt it every 1-2 years!
Old 11-01-2009, 01:56 PM
Restricted User
1BAD_LS1's Avatar
nobody drives a th400 on the street????
Old 11-01-2009, 06:18 PM
melchoir's Avatar
Only special people that don't like overdrive or lockup torque converters.
Old 11-01-2009, 06:33 PM
Restricted User
1BAD_LS1's Avatar
LOL ya I guess not many people would like to drive their car without OD and a converter that doesn't lock....
Just figured there were other people who did... I dont drive mine a whole lot (its not my DD)
Old 11-01-2009, 06:40 PM
98Camarod's Avatar
I'll let you know after I button my install up
Old 11-01-2009, 06:41 PM
98Camarod's Avatar
Or people that have enough power to not want a 4l60e....
Old 11-01-2009, 06:46 PM
Restricted User
1BAD_LS1's Avatar
Sounds good! I am buying one hope to have it in 2-3 weeks! The bad thing is that all the other stuff that is required to install the th400 is like $1500!!!!!
Old 11-01-2009, 06:48 PM
98Camarod's Avatar
Just wait until you can buy it used, that's what I did. I saved quite a bit that way
Old 11-02-2009, 01:17 PM
Restricted User
Zero4488's Avatar
I'd chime in but I'm new to the TH400's....but from what I've seen in other cars it's about how much power you make and how much abuse you give it...Personally I don't see why it wouldn't have a long and healthy life with the correct matinence...
-Dave
Old 11-02-2009, 01:36 PM
chasgiv3's Avatar
I've put about 1200 miles on my TH400. I did break a sprag once doing multiple burnouts on the street being silly. Cost me 500 to have it removed gone through and put back in. I replace the filter and fluid just before every season. The street does nothing in the way of abuse compared to making track passes. Trans brake is pretty brutal on the fluid even with the cooler.
Old 11-02-2009, 09:10 PM
Restricted User
1BAD_LS1's Avatar
atleast if they do break they are fairly cheap to have fixed... lol
I am thinking of going with 3.00 gears in my 9" instead of running the 3.70 gears with the th400
with 3.00 gears 65mph is 2300-2500rpm
with 3.70 gears 65mph is 2900-3100rpm
I figure being a turbo car the 3.00 gears shouldn't hurt at all....
what do you guys think?
Old 11-02-2009, 09:55 PM
Gingervitis Addict
slow67's Avatar
Doing burnouts or pedaling in 2nd?
Old 11-02-2009, 10:13 PM
Restricted User
1BAD_LS1's Avatar
OK guys... what is a surefire way to F-up your th400.
I am looking for things that are not so obvious to someone like me that isn't familiar with a rmvb transmission... Basically looking for DO's and DONT's!
is there a right way to do a burnout? I have linelock, i assumed just start in first and then shift to second turn off linelock and roll out, right?
Old 11-03-2009, 06:38 AM
b18cls1's Avatar
we have a customer that drives his th every day, 1.5 yrs now and no lockup will heat the fluid bad and will over heat the trans keep your temps under control and youll be ok, remember these trannys used to be stock in cars at one time, its not like they magically appeared and were never stock in a car
Old 11-03-2009, 07:28 AM
letsrunem's Avatar
Same here!
I've read that starting a burnout in 1st is a big no no.
Old 11-03-2009, 07:29 AM
cause4panic's Avatar
I think you start in 2nd, shift into third as soon as the tires start to spin then roll out, but im not 100% sure.
Old 11-03-2009, 07:39 AM
cambirdracing's Avatar
I have raced my 68 Bird with a th400 for 15 years. I have always started in 1st and shifted to 2nd and NEVER had a problem doing that. But I don't have a brake on it, I footbrake race it.
Old 11-03-2009, 05:39 PM
gsxr1k2's Avatar
Originally Posted by letsrunem
Same here!
Huh? Thats a new one on me. I beat my th400 like it owes me money. Its see's street/strip driving and I take it to the 11's @6400 da (thats 10's for sea level ******). The only way I could think to tear these trannys up is to neutral drop them or down shift them manually. I always do 1 to 2 gear burnouts. These trannys are so cheap to build you have to beat the **** out of them.....lol.
Old 11-03-2009, 05:50 PM
98Camarod's Avatar
This is what I found in my research:
try to get to 3rd for burnouts, don't let it hook hard during burnout, don't neutral or downshift at end of run, don't decel downshift, and if you do, don't hit the throttle again.
Pedaling in 2nd gear due to traction issues can be detrimental, especially with a full manual VB with no engine braking.
Don't do neutral drops...
Don't run it low on fluid....or with improper shifter adjustment.
Old 11-03-2009, 06:02 PM
weaklt1's Avatar
I drive my TA with a Th 400, rmvb and a brake whenever it is dry and nice out, so far so good.
Quick Reply: how long has your RMVB th400 w/brake lasted on the street? (miles)
