U-Joint for Alum DS for Moser 12-bolt
I've been using the original U-joint for a couple weeks, went to have the new Napa 447X U-Joint pressed on the driveshaft and noticed it did not have any kind of coating on the cups for an aluminum driveshaft. The Napa part #447X U-joint is recommended when using the upgraded yoke on the Moser 12-bolt, but i was wondering if their was a different brand U-joint i can use with this aluminum driveshaft. Thanks very much in advance.
