Ls1 Th400 flexplate bolts
Old 11-02-2009, 10:24 AM
wajouba's Avatar
Default Ls1 Th400 flexplate bolts
will these ARP # 244-2901 bolts fit on the Th400?? If i am using the following :
stock 98 dished flexplate
GM spacer
Stock Th400 converter
are these the same :
1) #244-2901
2) #12563533
Old 11-04-2009, 09:22 AM
wajouba's Avatar
this is a comparisant between the 2, I know one is a bit shorter, but is it sufficient enough... ARP said yes it is...
Quick Reply: Ls1 Th400 flexplate bolts
