looking to spray...
looking to spray...
well i sold my turbo kit and looking to spray a 300-350 shot....i do have stock 241's i need to upgrade and 3200 stall built tranny, my question i have a turbo cam the specs 232 226 dur. @050".588".574"lift on a 114 lsa n @110 icl, would this cam do me any good, really dont wanna spend for a new one....or what cam would be good, looking for good n/a power but something thats wakes up on the spray
Ring gap should be .030 for that size shot. Those cam specs are not ideal for N20, most generally the exhaustr duration is larger than intake duration for N20. You will also need bigger injectors. If you are talking about spraying the 408 in your sig you need a bigger cam.
up to a 300 shot on standard rings and 350 fogger on low tension rings. but spraying that much you better run a vacuum pump or some adequete breathers if you dont like having to simple green the engine compartment after every hit.
