Alternator mount
Old 11-06-2009, 10:14 PM
zittman's Avatar
Default Alternator mount
What do you guys using for a alternator bracket when you do not have power steering anymore and have a electric water pump? Ls1 into a Nova. Thanks
Old 11-06-2009, 10:56 PM
elias_799's Avatar
i use the speed inc relocation bracket with their alternator on my turbo car. it relocates the alternator to the pass side cylinder head. so i would assume that you can just get a shorter belt the usual if you do not have p/s and then you should be just fine. also you can get rid of all of your tensioners because the alternator bracket that speed inc provides will act as a solid tensioner.
Old 11-07-2009, 11:30 AM
mwatson185's Avatar
Bmr alternator only bracket
