performance chip, Drag radials w/o subframe connectors ?
I write checks with my mouth that my ass can't cash
so my buddy has a performance chip made for my car that plugs in and downloads onto the computer (you can also put it back to stock if u want) , i have no idea what it does but is it unsafe ? will i have gains ?...Also my friend with a trans am has some big 315 drag radials on it and i was going to bolt his wheels and tires on my car just for a couple races, will it tweak anything or hurt anything withought SFCs ? one more thing would a ported mass air meter do anything for me or would it be dangerous ??? Just a couple quick questions ! thanks...
Internet Mechanic
Not really drag racing.... but here is some info.
Post this in the External Engine Section for GEN III.
Also.... do not let anyone touch your computer unless they are a professional. You can **** up stuff very easily if someone has no knowledge of LSX stuff or if their expertiese falls in with a different type of car.
** There are no "Chips" when it comes to cars from 94+, All of them are a flashable PCM done via a laptop and cable.
Next, Test fit those tire, make sure they actually fit and not rub/grind
You won't catch real traction anyways, as for the subframe, the SFC's should be on there already. It is when you put a real tire on the car or your hitting it hard off the line, a street launch most times will not be powerful enough to do damage. Just day to day driving would put stress on the car.
Lastly, LEAVE THE MAF ALONE.
