Sponsored by: DashLynx
!wire mod write up, cant find it
Old 12-10-2003, 10:24 AM
770Guy's Avatar
Default !wire mod write up, cant find it
I may just be a Dar Dar and cant find it using the search option, but can someone hook me up with a write up on the wire mod, i got the motor out of my car and i figured i might as well clean up the engine bay while im waiting on my new motor.
Old 12-10-2003, 11:17 AM
Chop-Foo Director
PendragonZ's Avatar
This should work.
http://www.poltergeist.us/Misc/Wiremod
Old 12-10-2003, 11:26 AM
770Guy's Avatar
Perfect!
Old 12-10-2003, 11:39 AM
Copy & Paste Moderator
VIP1's Avatar
Others have done it without cutting. It usually involvs a bigger hole or dismatling the connecters themselves and then some creative routing.
--VIP1
Old 12-10-2003, 12:35 PM
Steve1969LS1's Avatar
--VIP1
This it true.. i dont personally like the huge hole way but if you hav the skills then the "dismantled connectors" way works well also.
We did the cut method on my SS (patient zero) a LONG time ago and there has NEVER been a problem..
either way it looks way cleaner with the wires gone.
Old 12-10-2003, 04:36 PM
PongoX11's Avatar
Yeah I did the cut method, solder and heat shrink tubing the wires back together. With a one inch hole with gromet the wires filled it perfectly.
Old 12-10-2003, 10:04 PM
770Guy's Avatar
I did the drill a big hole method, then I got some Clear silicone and filled the whole in, worked perfect.
Old 12-10-2003, 10:17 PM
gogogadgetcar's Avatar
good info
Old 12-11-2003, 11:03 AM
Ken@xxxxx's Avatar
Is there a writeup on the way to do it without cutting the wires? Never heard of that method before
