For Sale: 99 red SS M6 402 $worth?
1999 Camaro SS
Red
black int.
t-top
6 speed
$10k
Pm me for pics
Car is in good shape, some rock chips
Car has 190k
engine has 40k
trans has 70k
rear end has 15k
engine mods-
Ls2 block-Callies crank, H-beam rods, mahle pistons, arp rod & main bolts
Patriot stage 3 Ls6 heads
Melling ported oil pump
Morel hyd roller lifters
Comp cam 248/250 .612/.622 LSA 110
Comp shaft mount adj roller rockers
FAST 90 intake
Nick Williams 90 TB
SLP filter intake
42 lb/hr inj
255 walbro fuel pump with hot wire kit
Kooks long tubes with custom 3" true duels to the bumper with H pipe and cutouts
Drivetrain mods-
Fidanza Alum flywheel
Spec 1
B&M ripper short throw shifter with cut stick
Mcloud adj clutch master
trans has upgraded 3rd steel shift fork
4.10 gears (stock 10 bolt)
Susp/Brakes/Body
Hawk pads
Front bear eradispeed rotors
1 1/4" drop springs
custom welded in sub frame conn.
Red
black int.
t-top
6 speed
$10k
Pm me for pics
Car has 190k
engine has 40k
trans has 70k
rear end has 15k
engine mods-
FAST 90 intake
Nick Williams 90 TB
SLP filter intake
42 lb/hr inj
Drivetrain mods-
Spec 1
Susp/Brakes/Body
Hawk pads
1 1/4" drop springs
