Switch to 1/2" wheel studs
Old 11-18-2009, 10:45 PM
meatman's Avatar
Default Switch to 1/2" wheel studs
Anyone run 1/2" studs instead of 12mm x 1.5s? I see they are listed on Thunder Racings website. Only issue I see is that the knurl on stockers is .509 and on the 1/2" ones is .625. Think a tenth of an inch would make them a total bitch to press in?
They are half the price of the longer 12mm ones and I need that extra length to pass NHRA tech.
Old 11-19-2009, 09:24 PM
ss1
ss1's Avatar
Don't do it unless you can get your axles drilled. There is no way you'll get a stud with a .625" knurl into a .509" hole.
Quick Reply: Switch to 1/2" wheel studs
