Monthly Specials - www.PartsTaxi.com
Old 11-19-2009, 12:48 PM
Closed ex-Sponsor Account
PartsTaxi.com's Avatar
Default Monthly Specials - www.PartsTaxi.com
Hey guys! It's been a while since I've been on this forum and for that I'm sorry. I put together this list of specials for you Vette guys. Please keep in mind I am a GM dealer, I can get you ANY GM PART still in production. Please contact me directly for any assistance.
Genuine GM C6 Corvette PAL
17800593 - C6 Corvette Personal Audio Link - $149.58
19170234 - GM Genuine Accessory Splash Guards - $91.88
C6 Maintenance Parts
12626224 - Single UPF48R Filter - $8.38 each
To order a case of 12 UPF48R use Part Number 12packUPF48R for $95.76 total (thats $7.98 each!)
25329389 - UPF44 Oil Filter $8.22 each
89017524 - PF48 Oil Filter $4.98 each
19210283 - PF46 Oil Filter $4.78 each
15861929 - Passenger Compartment Filter - $42.62
10342024 - LS2 Air Filter Element (Need 2) - $16.42 each
15776148 - LS3 & LS7 Air Filter Element - $85.44 each
25940997 - LS9 Air Filter Element - $114.14 each
24241872 - Magnetic Drain Plug - $14.65
OEM GM Brake Pads - Standard C6 and Z51
19152862 - Front OEM Pad Kit - $161.46
89026853 - Rear OEM Pad Kit - $99.40
Ceramic Brake Pads for Stock and Z51 systems
88909667 - Front Ceramic Pad Kit - $88.37
88909668 - Rear Ceramic Pad Kit - $59.31
Base C6 ACDelco Drilled & Slotted Rotors
19183532 - Right Front - $94.19
19183533 - Left Front - $94.19
19183534 - Right Rear - $87.09
19183535 - Left Rear - $87.09
That's $362.56 for all 4!!!
2008 and newer Key & Fobs (transmitters)
25926479 - #1 Key Fob - $89.72
25926480 - #2 Key Fob - $89.72
25995382 - Key (does not come with Fob) - $38.14
Grand Sport Rear Wide Body Kit for Vert - $1243(these panels cost slightly higher then normal kit)
Grand Sport Front Wide Body Kit - $2289.72
Chrome Z06 Emblems - 25919017 - $21.56 each
427 Script Emblems - 17803320 - $115
Rear Wide Body Kit - This is the complete rear wide body kit. ZR1 & Z06 are the same. Kit includes rear quarters, all fasteners, seals brake ducts, scoops and wheel liners. $1148
Z06 Rear Splash Guards
15818636 - Right Rear Splash Guard - $44.33
15818637 - Left Rear Splash Guard - $43.24
11519444 - Retainers - $1.38 ea. x 10 needed
ZR1 Front Wide Body Kit - This is the complete front wide body conversion to install ZR1 panels on the front of your C6. Kit includes fenders, fascia, seals, all hardware, ornaments. COMPLETE KIT. $4790.58
Not included in ZR1 Kit, but available for extra cost;
ZR1 Front Splitter - 25938053 - $1349
ZR1 Hood - 15844745 - $3679.55
ZR1 Rocker Panels - 15845019 & 15845020 - $948.01 each
ZR1 Roof Halo - 15843296 - $1386.05
ZR1 Roof Panel - 15843295 - $2190.73
Z06 Front Wide Body Conversion - This is the front wide body kit with the Z06 panels. This includes everything for installation minus the inner plastic liner that is glued to the body/frame. $3845.82
20822934 - Upgraded Metal Sway Bar End Links - $22.78 each
ZR1 Front and Rear Sway Bar Kit - Kit Includes front and rear sway bars and insulators $199.84
Z51 Front and Rear Sway Bar Kit - Our most popular bar kit. Kit includes front and rear stabilizer bars for Z51 - $191.84
Z06 Front and Rear Sway Bar Kit - Kit includes Front and Rear Stabilizer Bars for C6 Z06 and insulators - $224.83
C6 Z06 Shocks
10313647 - Front Shock - $61.43 each
25819268 - Rear Shock - $60.42 each
Z06 Brake Upgrade Kit - Kit includes both front calipers, both rear calipers, both front rotors, both rear rotors, front and rear GM OEM pads. We prefer not to substitute ACDelco as a replacement on this kit. - $1799.99
Z51 Brake Upgrade Kit - Kit includes both front rotors, both rear rotors and all four caliper mounting brackets - $489.78
15268606 - Tire Pressure sensor for 2010 and up - $39.99
25758220 - Tire Pressure Sensor for 05-09 - $55.08
15234846 - Tire Pressure Sensor Nut 05-10- $3.73
LS7 Clutch Kit - Kit includes LS7 Clutch and Flywheel - $431.97
89059282 - LS6 Slave Cylinder - $125.01
12564455 - LS6 Master Cylinder - $127.49
14061685 - Pilot Bearing - $11.99
19172324 - Genuine GM Accessory Performance Exhaust Cat-Back - $1219
19172326 - Genuine GM Accessory Off Road Cat-back exhaust - $1219
ZR1 Spoiler Kit - ZR1 Spoiler kit includes spoiler and 10 nuts needed for installation - $429.83
Full Width Design Spoiler
19172807 - Primer - $235.95
19172808 - Victory Red - $278.71
19172809 - Velocity Yellow - $278.71
19172810 - Machine Silver - $278.71
19172811 - Black - $278.71
19172812 - Jetstream Blue - $278.71
19172813 - Crystal Red - $278.71
19211166 - Cyber Gray - $278.71
19211165 - Switchblade Silver - $278.71
19211167 - Atomic Orange - $278.71
Stock Spoilers also available - Pricing as low as $144.86 - Please contact me for numbers/details
Genuine GM Console Lid with Jake Skull - 19209851 - $144.44
Genuine GM Accessory Console Lid with Logo
17802448 - Ebony With C6 - $99.30
17802449 - Cashmere With C6 - $99.30
17802450 - Cobalt Red With C6 - $99.30
17802451 - Titanium With C6 - $99.30
17802452 - Ebony With Z06 - $99.30
LS2 Color Keyed Fuel Rail Cover Set (left and right)
17800101 - Daytona Sunset Orange With Silver Lettering - $149.87
17800102 - Machine Silver With Red Letering - $149.87
17800103 - Victory Red With Silver Lettering - $149.87
17800104 - LeMans Blue With Red Lettering - $149.87
17800109 - Artic White With Red Lettering - $149.87
17800110 - Vlack With Red Lettering - $149.87
17800111 - Millennium Yellow With Red Lettering - $149.87
17800112 - Magnetic Red With Silver Lettering - $149.87
17802119 - Velocity Yellow With Red Lettering - $149.87
17802120 - Monterey Red With Silver Lettering - $149.87
19170525 - Atomic Orange With Silver Lettering - $149.87
Genuine GM Accessory Front End Bra
19202129 - With License Plate Opening - $89.73
19202139 - Without License Plate Opening - $89.73
Thanks!!!
Kevin
www.PartsTaxi.com
302-645-6221 x126
302-295-1240 - Fax
302-883-0227 - Parts Department Direct
kevin@lewesautomall.com
