keep getting a leak around trans cooler
Old 11-20-2009, 01:43 PM
stevez2885's Avatar
Default keep getting a leak around trans cooler
i got a performabuilt lvl 2 trans and for some reason i keep getting small leaks where my aftermarket trans cooler is....anyone know if theres a steel braided line kit or something thats sold instead of having to use the rubber lines with clamps?
Old 11-20-2009, 01:53 PM
jsteele90's Avatar
you can buy steel braided line from summit, jegs, etc. or use the hose clamps that dont pinch into the hose. also are you using the atf specific line for your trans cooler installation
Old 11-20-2009, 06:17 PM
stevez2885's Avatar
yeah im using the lines that came with the trans coller from performabuilt but i guess ima have to switch up the clamps because this is like the 2nd time ive had to deal with a leak
