who sells the adapter to put rear C5 o2s in front?
are you trying to use vette rear o2's as fronts in your longtubes??... if so, it's the bosch 13111 that you're looking for... any 4 wire o2 is just a narrow band o2, the only difference will be the length of the wire and the connector
i dont kno about that part # but X2 on the bosch o2's for C5's rear. Will snap into place like it came that way. connectors, wiring, and sensor are all the same. only difference is the length of wire. good luck
I was unaware of that, I have a c5 and c5 sensors up front now but I want to do away with my splice and get the adapters. figured the fbody had the same plug config.
dave
dave
