Tick M/C Pedal Play
Old 11-23-2009, 09:25 PM
vatechguy3's Avatar
Default Tick M/C Pedal Play
i got everything installed and adjusted per the instructions, including removing the spring and now have about 50 miles of driving.
my question is, there seems to be alot of free play at the top of the pedal. is there anything i can do to remove this free play?
thanks
tony
Old 11-23-2009, 09:40 PM
LS1TECH Sponsor
Jonathan@Tick's Avatar
There will probably be about 1/2" of free play at the top of the pedals travel. If its more than that, try pumping just the free play area using you hand and the free play should gradually get tighter and tighter. It probably just has a bit of trapped air still in the system...
Old 11-24-2009, 05:19 AM
vatechguy3's Avatar
thanks for the quick response.
the free play is about 1" - 1-1/2" when i pump with my hand.
will try pumping it up and seeing what happens. but my buddy and i bled the system with almost 1 full bottle of fluid. wanted to make sure there was no old fluid going through the new master!
tony
