trying to make a nasty mud motor out of 290 horse gm crate
first of all this is going in a 68 chev. 3/4 ton. 37inch irok's, play and pull people out of mud and etc..
i looked the part # up on jegs for the motor. it is #809-10067353.
basically a low comp 350, but is 4 bolt and has decent rods. pistons are cast
this motor comes with 76cc heads and has 8.5;1. i need this at or above ~11:1. i will swap pistons if i need to as this is a brand new motor sitting in garage and will need no machining to swap. i will leave bottom end alone except i have arp rod bolts going in. should hold 6500 ok.
the cam i have investigated for me is http://www.compcams.com/Cam_Specs/Ca...?csid=236&sb=2
the power band will be small but i should get a hell of a torque curve out of the 106 ls. i do not care about drivability as this is a toy..
other parts already purchased
225cc patriot heads 64cc (i know big but going for max effort, and got a deal)
rpm airgap port matched to heads, 1 1/2" open spacer
1 3/4 3"collector headers, bullets
msd hei
6al
750 hp holley
truck has 4.56 gears and a truck trans. (sm420 for those who know, granny gear 4 speed)
any other recommendations??
please don't anyone tell me to get a vict. jr. this will not help this motor unless i spin 7000
if i shave my 64cc heads what can i get comp. to with the stock pistons...
will they live???
msd hei
6al
750 hp holley
will they live???
when compression is actually calculated on that engine, its comes out to a more accurate 7.8:1. Pistons will have to be changed and the block zero decked unless you just use a .250" dome.
