resurfacing flywheel
Old 11-27-2009, 05:26 PM
KOS
KOS's Avatar
Default resurfacing flywheel
on a 98 LS1 can you resuface the flywheel without any problems?ive heard of shimming and i also have an adjustable master is that enough to compensate for the material removed?
Old 11-28-2009, 02:40 PM
KOS
KOS's Avatar
ok just read the shimming post..... anybody have an opinion about resurfacing the flywheel?
Old 12-01-2009, 02:01 PM
SPEC-01's Avatar
The short answer is: Yes. You can resurface the flywheel.
The more in depth answer has some qualifications:
You have to be careful when machining the OE flywheel because if you remove too much material or you will affect the clutch assemblies overall height. Taking any more than .015" out of the flywheel's thickness will bring the engagement point down and as a result impact the clutches release.
Has the flywheel been resurfaced before? Do you know how much material they removed?
Old 12-01-2009, 08:53 PM
KOS
KOS's Avatar
not 100% sure if its ever been resurfaced..............so your saying any more than 15thou becomes a problem.
Old 12-02-2009, 08:45 AM
SPEC-01's Avatar
That is correct...we don't suggest taking more than .015" off of the OE flywheel.
Quick Reply: resurfacing flywheel
