Coil bracket questions
Old 11-30-2009, 06:26 PM
c20rj's Avatar
Default Coil bracket questions
Hello all, I have a set of 02 vette coils, and I just found that they will not mount up to lq4 coil brackets, the holes do not line up. If I order the corvette coil brackets will the brackets still bolt up to the valve covers? (lq4) Thanks!
Old 11-30-2009, 06:33 PM
LS1MCSS's Avatar
Yes they will. You can probably find a set of brackets on ebay.
Old 11-30-2009, 08:30 PM
c20rj's Avatar
Thank you!!
Old 12-01-2009, 05:59 AM
toadzq8's Avatar
The coils will sit lower on your valve covers so make sure you don't have any clearance issues Also your LQ4 plug wires will be long.
