sell it and buy a plate kit from hsw or n20 outlet. Both companies make quality components for the ls platform. Do some research, that zex is junk for efi, their carb stuff seems to do ok tho.
What is a safe shot to run on a stock fuel system? I've heard 125 shouldn't be a problem.
Can I spray this much without worrying about damage. using a window switch and bottle heater with wot switch?
Depends on what all is done to the car. The cars stock fuel pump is good for supporting about 450 total rear wheel hp. Injectors will be something you need to concider as well.
If it were mine I would sell the Zex system and put a good wet system on the car..
I see you are in Killen.. We are right down the road from you.
Dave
