Anyone using the HSW interface with a wet shot?
Old 12-03-2009, 11:08 PM
LilJayV10's Avatar
LS1Tech 10 Year
Default Anyone using the HSW interface with a wet shot?
I am slowly gathering all the parts for my engine build this winter. I am putting a wet shot on my car, I am going to start at 75 but I am sure I will end up at 150. I am using the HSW plate.
I have the mircoedge controller already and I am wondering about the interface. It seems that it was designed to use with a dry shot but can it be used with a wet shot?
The main reason I am asking is because of the timing retard function. I would like to have a good N/A tune and still be able to run a 150 shot safely. Of course I will be using the correct spark plug.
Any comments or experience would be great!
Jason
Old 12-05-2009, 05:24 PM
jeepers_88's Avatar
Youre doing exactly what I do. I have their 78mm wet plate kit and I also have the microedge and interface, I use the interface just to pull timing, it pulls three degrees for me when spraying, and im on a 150, all the time. Im running a tad lean right now on the wideband, and as soon as I get around to it, Im going to use the fueling function to add a bit more fuel for me to help richen it up a bit, its a definate plus
Old 12-05-2009, 05:28 PM
tnmotown's Avatar
LS1Tech 10 Year
Im doing the same thing. I have the wet plate kit coming in and ordered the interface also. Only because like you said, I wanna run full potential N/A and then when i want, retard the timing for nitrous. Cant go wrong
Old 12-05-2009, 05:33 PM
LilJayV10's Avatar
LS1Tech 10 Year
sounds good. thank you for the replies
Old 12-05-2009, 08:46 PM
conde'strans's Avatar
You can't go wrong with the interface I'm about to install it for my 150 shot. I first saw it function on my friend's h/c 150 shot formula and loved it.
Old 01-03-2010, 07:51 PM
john shea's Avatar
My hsw wet plate kit just arrived . I'll have to save a little more for the interface and window switch.
Old 01-04-2010, 09:40 AM
Nick@HSW's Avatar
Nick
