watts link good for drag racing
LS1Tech Premium Sponsor
watts link is nothing more than a track locator... they both do the same job. the purpose of a watts is mainly for the roadcourse guys that are looking to not have any rollcenter or track centering change that can happen with a panhard design. while the panhard is quite long in the f-body the track centering doesn't change much, the watts will not change at all during suspension travel. if you are doing street/strip duty the standard panhard works just fine and you will see no change in et's by installing a watts. the watts is appealing to the guys that drive on the streets as well as roadcourse/autocross and run at the dragstrip with the same car.
LS1TECH Sponsor
It's not just to change roll center, in fact I run my RC as near to stock as it gets. What a Watts link does it get rid of the geometry change that is inherent with a PHB.
Anytime the body moves up and down with a PHB, it's also shifting left and right... A watts link stops that. Even on drag cars this happens, think about the car squating when you launch it...... and it often makes a move to the left of right. That isn't helped by the fact that as the suspension compresses the body is moved relative to it.
Do I think that a Watts link will make a killer drag car vs. a PHB? No. Does it hurt you at all? No. Do I think that it can help cars leave a little more straight and track better as the speeds climb? I do because I see it in my car at similar speeds.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
After I installed one on my t/a the car seems more planted.Even in a drag race the car is more solid.I wanted my car to be a canyon carver/drag race street car.I don't think I would install one on a drag strip only car,but for an all around car a watts link kicks ***.I would be supprised if you installed one on your car and didn't like it.
