ls1 rebuild
Depends on how you want to rebuild it. Are you going to use forced induction, or do you want a mostly stock setup?
On my rebuild I used a stock bottom end that had machinework done by LME, but I had to get new pistons (I got Wisecos), ported stock heads, a TSP XS 233/239 cam, 78mm FAST intake and 78mm FAST throttle body, ARP rod bolts and head bolts. Does that help?
the car is mostly for street use . i just wanted to get some idea what mods i can add to get some horses out of it before giving motor for rebuild . that would be cool if there is some list of parts i can tell them to put it when rebuilding . more suggestions are welcome . come in all the guys with rebuild ls1. thanx
