806 heads need help
806 heads need help
how shitty will 806s flow on and ls1 with and ms4 cam and ls6intake and full exhaust because i bent the valves on my ls6 heads just wonderin if i should just wait for the heads to get fixed
They are definitely going to kill some power. If you are planning on getting the LS6's fixed, fairly quick, I would wait and save the labor and money in gaskets. Now if you need the car to run because it's your daily driver, then they will work to get you by. Everything will bolt back up with either set of heads.
Jon
Jon
Just a suggestion but I think I would find out how the valves got bent and make sure it doesnt happen again. If you already have the 806s you could swap the valves out with the ls6s valves and get a valve job.
