po174
Old 12-11-2009, 04:47 PM
blown90camaro's Avatar
Default po174
blew a po174 code, (bank 2 running lean) naybody know any solutions??
Thanks in advance!!
Old 12-11-2009, 04:58 PM
mknight759's Avatar
could be a bad o2 sensor can you swap them around see if the code changes
Old 12-11-2009, 10:40 PM
massls1guy's Avatar
I had P0174. It ended up being a hole in a PCV hose. I changed most of the PCV hoses when I swapped in my LS6 valley cover a while back. I left the original ~3" hose that connects between the PCV valve and the intake manifold and that's where the leak was.
Old 12-12-2009, 10:18 AM
thanks guys im gonna go ahead and switch the 02 sensors and see what happens
