head gaskets???????
Old 12-14-2009, 06:10 AM
pewterfbody's Avatar
Default head gaskets???????
What size head gaskets do i need? It is stock bore size.
Thanks
Old 12-14-2009, 06:55 AM
PREDATOR-Z's Avatar
Perhaps a bit more info. What is your head chamber bore size?
If both are stock then you need stock gaskets, GM MLS is one of the best to date.
Old 12-14-2009, 09:05 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Agreed, more info on the combo would be nice! Are you running an aftermarket camshaft, and if so, what are the specs? What heads? Stock stroke as well as bore?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
