oil pump driveshaft removal
had a small block built recently. well looks like the engine builder used a big block oil pump driveshaft by accident as it is too long in block when compared to a stock one.
now here is question i have the motor in car already. now my question is can you pull the oil pump driveshaft rod through top with long needle nose pliers?
or do i have to do the inevitable and pull the pan and drop oil pump?
thanks for input
thanks for input
