Clutch Issues...
Clutch Issues...
I've got a 2004 GTO. I recently put in a zoom clutch, SS braided lines with the remote bleeder along with a new Slave.
Car was fine for the first 1500 or so miles and engagement was half way up. Went to the track, made several passes and everything was great. Drove it for about another 2 weeks and the engagement got closer and closer to the floor and is now at the floor. Driving around town it's difficult to shift and any kind of spirited driving, forget about it. I've tried bleeding the fluid with no improvement whatsoever. The clutch isn't fully disengaging. I can put it in first, hold the clutch down, rev and the car starts to roll. The pedal is a little bit stiffer than stock and I have no complaints about it. The slave is also not leaking. I just don't understand how it was fine at first and now it grabs at the floor. I already know about the Tick MC and I don't have the money right now for it because of the holidays, maybe in the near future though. Asides from that, Ive heard of guys shimming the slave cylinder to cure this issue. Do you guys think I should do this, at least until I can buy the Tick MC?
Thank in advace,
Alex
Thank in advace,
Alex
Go with a Tick and be done. I just put a monster level 3, new slave flywheel and tick master with remote bleeder. It fixed my grinding problems and pedal inconsistency. I have a 99 z28
Thank in advace,
Alex
Thank in advace,
Alex
So I pulled the tranny and found that the pressure plate bolts had come loose. Which kinda bothers me because I torqued the bolts properly when putting the clutch in. Put some threadlock on this time and re-torqued the bolts. Put it all back together, bled the clutch and it drove fine. Been driving fine for a week now. Clutch engages just past half way now.
I just have a stock replacement.
Thank you, I will definitely look into that.
You could try the stock adjustable master cyl. and see if that helps.
https://ls1tech.com/forums/manual-tr...r-writeup.html
