broken t56 skip shift solenoid
Old 12-21-2009, 10:58 AM
stevo9389's Avatar
Default broken t56 skip shift solenoid
after removal from my 94 formula the skip shift solenoid was physically damaged to the point that i would not be able to reconnect it to the pigtail. if i just have it (C.A.G.S./C.A.R.S) tuned out on the PCM would it cause a problem still if i left the sensor disconnected?
Old 12-21-2009, 11:33 AM
armyboyatc's Avatar
If you delete it outa the computer it shouldnt matter if its hooked up or not. My skip shift is unhooked and I havent had any problems.
Old 12-21-2009, 12:02 PM
ssjTAdriver's Avatar
Yes if the logic is no longer in the computer then you should not have to worry about it engaging the solenoid at any point. The light shouldn't even come on. Does it? GL.
Old 12-22-2009, 06:29 PM
stevo9389's Avatar
thanks for the responses. just wanted to be sure i wasnt overthinking the issue.
Quick Reply: broken t56 skip shift solenoid
