Forward Mounted Shifter install problem
What friggen drill bits are to be used when drilling the shift rail? I have burned up four bits so far.
Any help is appreciated.
-Ryan
-Ryan
Drill bits.
The outside might be hardened.Try taking a grinder and making a flat spot to drill on.It will take the harden part off and give a flat surface to drill.Just my 2 cents.Good luck
