clutch problems
clutch problems
I have a 99 z28 ,t56 that I swapped for a rebuilt one from mans-tran. Can't get it to go into gear cranked up. Tran shift not cranked. Blead for 3 days used slave bleed screw and mity vac. new clutch,flywheel, and master. Clutch and flywheel from f1 racing . Dealer says it's the one for my car. New trans seems to sit a little further back than the old one, notice this as I tried to shift gears. I have a little petal, not enough to put it in any gear. Did't bench bleed master, instruction told me not to, said I could damage gasket if overstroked. I have alot of new varibles. Think I'm letting air in somewhere. Any advice is appreciated
