Where can i get my Throttle Body Ported????
I would think that buying a new larger TB would be less costly for you. In order to port a TB, the TB would have to be disassembled. Then the bores machined out. Then new plates would have to be made. Then reassembled. I always preferred to keeping my factory unit (just in case) and buy & install an aftermarket unit.
1 Post
That is very wrong. Quite the opposite. Aftermarket throttle bodies to little because the hole in the intake manifold is only so big. Taking off and porting the throttle body is easy, and you can feel the difference. Search in the external engine section for people that have done it. It was like the first thing I did to my car.
