alternator hookup CONFUSION
Old 12-24-2009, 09:34 AM
71 chevy's Avatar
Default alternator hookup CONFUSION
Im running a 5.3 with megasquirt ( no ecm)
with an alternator that came with it.
the adapter has two wires. it says connect one to lamp and the other to switched ignition
my question is, what does the second wire do? is it a sense wire? if so, can I connect it to my main junction instead? does it even need to be connected, and why?
thanks
Old 12-24-2009, 12:46 PM
hifi875's Avatar
it turns the alt on
Old 12-24-2009, 06:53 PM
TTLS1GP's Avatar
the alternator needs a 10ohm resistance to ground to activate the field.
the indicator lamp provides this as well as letting you know what the alt is doing.
The power source activates the rectumfinders inside the case.
Old 12-24-2009, 07:02 PM
BigDaddyDupree's Avatar
i have an alternator from a 2004 chevy 5.3 on my s-10 and i have a 1/2 watt 470 ohm resistor and hooked to the L terminal i believe. and it charges great
Old 12-24-2009, 11:25 PM
71 chevy's Avatar
so just one wire is hooked up?
Quick Reply: alternator hookup CONFUSION
