am i using the wrong bolts?
during the tear down of my h/c swap.. i neatly put things in a bag with the assosiated part. or if anything i think i did.. anyways, is this the correct bolt that holds the coolant pipe and plugs down?
I am working on the car right now, so if more pics needed, i can post! please help!
No that is most likely a bolt that holds the coil pack down and possibly a wire harness is held down on top, the coolant x-over bolts have no stud on top and have aprox twice the threaded length to them than the one you are showing fwiw
That is a coil pack bolt it looks like, however, my crossover tube bolts do have heads sticking out the top like that but obviously with more thread showing through the bottom.
