Ok to extend wideband wires?
Is it ok to extend the wiring from the sensor to the box beyond factory wiring? I dont want to mess up signal transfer by adding connectors and lengths of wire. Thanks!
wide band wire extension
No it won't disrupt the signal at all just use the same gauge wire and a good connector and you will be good to go. I had to do it on a previous build and it worked fine.
