Ok to T off vacuum lines?
Thread on this recently. I ran a vacuum manifold, drilled and tapped fitting where my map went in my fast 90 and run all the stuff off the vacuum manifold. Running 3 bar map, bovs,adjustable fuel reg, eboost 2 reference,hobbs switch for second pump. Still need to run vacuum /boost reference for alc injection. So far not seen any problem doing it this way. The main line is good size. Have pic of this as said recently in the other thread. Got the vacuum manifold off ebay. nice anodized and metal fittings,good quality and cheap.
