ANyone have the edit fuel:air ratio table worked out to air/fuel raio?
Old 12-18-2003, 08:22 AM
GrannySShifting's Avatar
Default ANyone have the edit fuel:air ratio table worked out to air/fuel raio?
How do you get from the edit table (fuel/air ratio) to the shown air/fuel commanded ratio that you can see with EFILive or Atap?
Old 12-18-2003, 11:06 AM
deezel's Avatar
I'm pretty sure its this:
commanded AFR = 14.7/(EQ ratio) where the EQ ratio is the value in the PE vs RPM table
Old 12-18-2003, 04:58 PM
Bink's Avatar
Yes to what deezel said. Closed loop = O2 ->14.7
Open Loop = Stoich Table (F/A Multiplier Table
->> 14.7/ Value from F/A cell
PE = 14.7/multiplier from PE-RPM + PE-Temp tables
FWIW.
joel
Old 12-18-2003, 05:34 PM
Thats what I was looking for thanks guys
