Finished my stock Z28 exhaust pipe trim parts.
Old 12-18-2003, 12:57 PM
emarkay's Avatar
Default Finished my stock Z28 exhaust pipe trim parts.
I could post the details here, but I'll send you to a post about them at the EFILive board:
http://www.efilive.com/forum/viewtopic.php?t=331
While you are there, look around, if you are not familiar with EFILive
I used the thin aluminum sheet found at most hobby shops and configured the templates for 3 parts that fit on one sheet. It was fun!
MRK
Old 12-18-2003, 01:16 PM
onebadz's Avatar
Im confused what is this for, are you going through the side trim with the tips?? Please clairify.
Wes
Old 12-18-2003, 03:30 PM
NightHawk's Avatar
Looks good man
Old 12-19-2003, 10:22 AM
emarkay's Avatar
It's like what I used to do, put a 1" strip of aluminum tape around the outside, but that was not "permanent", so I am "wrapping' the outside in aluminum sheet - Yea it's apperance, and not "performance", but I like those rectangular pipes and I wanted to accentuate them.
I do need to add this to my "mod' list on my homepage, and I'll also post the template info, too.
Old 12-19-2003, 11:39 AM
cudaeh's Avatar
dosent look half bad... .... .... ... um.... yeah... i think ... ... ..
yeah
Old 12-19-2003, 12:20 PM
Humanitarian
Joe "Preachers Sheets" DIESO's Avatar
Don't take this the wrong way but I think it's looks horrible.
Old 12-19-2003, 12:31 PM
cudaeh's Avatar
well if it wernt for the overlaping edges it would look good youve got a good material and a great idea... um... maby if you make the parts butt up agenst each other and solder them together... or even making each peace mount sepprat from the others? just trying to give some ideas.
Old 12-19-2003, 01:13 PM
PongoX11's Avatar
Yeah, looks great from behind... but the sideshot just looks like a tip, with a tip on it
Old 12-19-2003, 01:27 PM
Humanitarian
If I was really into it I would sand down the tips, spray them with a clear coat and have them shine that way.
Old 12-19-2003, 01:42 PM
hawgs's Avatar
They do make chrome Z28 tips.
Old 12-19-2003, 05:27 PM
Administrator
unit213's Avatar
Sorry, but...
Old 12-19-2003, 08:00 PM
emarkay's Avatar
The chrome (actually stainless steel) ones have the wrong intake offest - so they are not centered.
No prob to those that don't like, that's cool!
Hey, at least I didn't put chukwagon wheels with skateboard tires on the car! (where's that puking smiley when I need it...)
I originally painted and cleared, but the condensation water is acidic, and eats thru most paints.
It is a tip with a tip - all I really care about is the rear rectangles.
Can't solder aluminum, and there are no overlaps - the top part is tabbed and folded horizontally, and the bottom is doubled only across the bottom for extra protection but the rolled edges are all one layer.
Thanks for comments.
Hey Unit, I think you need some Pepto Bismol
MRK
Old 12-20-2003, 04:24 PM
emarkay's Avatar
I have posted templates and information on my homepage - see "mods" section - in sig!
Quick Reply: Finished my stock Z28 exhaust pipe trim parts.
