Head swap now no gauges? Please help
I just installed Patriot LS6 heads on my car, when I fired it up, my oil and temp gauges are not working.. I know for sure that I put the ground straps on the back of the drivers side head, there was 3 ground wires and I'm sure I plugged in the map sensor.. What could be the culprit? I never did deenergize the battery, do you think its possible that while all of the work was going on I shorted out a hot wire and it blew a gauge cluster fuse? Any help would be appreciated..
Thanks
Bryan
Thanks
Bryan
