LS6 Intake Question
Old 01-04-2010, 09:08 AM
TomM's Avatar
Default LS6 Intake Question
How many different part numbers are there for these intakes......
T,
Old 01-04-2010, 03:34 PM
ChrisBorsheim's Avatar
I think there's just the one, Tom.
I had to research mine a while back to verify that it actually was an LS6 intake and I did a search on this board that broke down all the part numbers for the various stock intakes.
Old 01-04-2010, 03:41 PM
The old LS1 intake with the EGR setup is 12560688.
The Stock 2001-2002 F-body LS6 is 12561184.
The Z06 LS6 is 12573572.
Old 01-04-2010, 03:44 PM
TomM's Avatar
So the 1184 is a stock LS1 intake....
and the 3572 is the more desireable one ......
T,
Old 01-04-2010, 04:05 PM
gofastwclass's Avatar
T,
No, the 1184 is an LS6 intake from an F-Body. The Z06 intake is basically the same as an F-Body intake, the difference is the Z06 intake won't have the brass bosses for the throttle adapter since all LS powered vettes are Drive By Wire and F-Bodies weren't. "More desirable" isn't really the situation here, just externally different but no performance difference. You can take a Corvette intake and use a cable throttle with it but you will have to install the brass nutserts or have some other method of attaching the throttle cable bracket (ask me how I know this).
Quick Reply: LS6 Intake Question
