You guys remove front sway bar?
Old 01-05-2010, 05:08 PM
1SLwLS1's Avatar
Default You guys remove front sway bar?
Was looking at clearances with my new BMR Tubular Turbo K and with sway bar still hooked, even with one wrong link(too short, rattling), and noticed not much room. Do you guys remove the sway? What about motor mounts, do you guys use solid? Clearance issues with solid/poly/stock etc?
Old 01-05-2010, 07:43 PM
Zombie's Avatar
no sway bar here.
Old 01-05-2010, 09:05 PM
Firechikn's Avatar
Go ahead and install the extreame rear, remove the front and you'll have less roll than with both stockers. That's the way my car is.
Old 01-05-2010, 09:24 PM
1SLwLS1's Avatar
def not worried about roll. The front is already obsolete with a short spacer on one side. Both front and rear are BMR units.
My last car, 02 mustang gt had no front sway bar for over a year and stock rear.
I am mostly just curious because I dont ever see/notice it in build threads or talked about much. I guess maybe im just not that observant or it isnt talked about at all.
