ls2 cable throttle bracket
We have two brackets depending on what TB you are running. We have a smaller bracket that just bolts to the back of the TB if you have the supplied hole. We also have a bracket that acts as a small TB spacer with the two-hole bracket cast into it. It is held in place by the TB bolts that fasten the TB to the intake. The small one is $29.99 while the spacer setup is $109.99. Let me know if you need one!
Jon
Jon
