Front tires skip when in reverse
Old 01-10-2010, 05:12 PM
Ryanmgaspard's Avatar
Default Front tires skip when in reverse
When going in reverse no matter how much the wheel is turned, the front tires will skip, slide, jerk across the concrete almost as if something is binding up and making the tires skip. I replaced upper and lower ball joints, inner and outer tie rods, both sway bar endlinks, and the steering rack and still have the problem. I don't have any alignment issues and the car tracks straight. Will the limited slip cause this? Maybe both wheels are spinning at the same rate instead of the inner tire going slower causing the car to pull backwards instead of turn.
Old 01-10-2010, 05:20 PM
98pontiac's Avatar
How do you know you dont have any alignment issues? what is your toe set at, and what is your caster measurements? you should have received a printout when you got it aligned. You do not have limited slip in your front wheels... it is an aligment issue, regardless if the car drives straight.
Old 01-11-2010, 07:37 AM
As far as the lsd, I've heard the clutches inside the differential will sometimes get screwed but where both tires want to pull the car straight backwards instead of letting it turn. I had one alignment shop pull me in specs but the car would dart all over the road, went to another shop and the car drives beautifully, no darting and steers straight. I did not get a print out of alignment specs.
Old 01-11-2010, 07:40 AM
Firebirdfan's Avatar
Subscribed. My 5.0's doing the same damned thing I want to know why.
Old 01-11-2010, 08:05 AM
Save the manuals!
wssix99's Avatar
Have you had someone observe from the outside while you go in reverse? Do both wheels skip and do they both skip if you are turning right or left?
Maybe you have a sticking brake caliper?
Old 01-11-2010, 08:37 AM
USArmyZ28's Avatar
Dont want to insult intelligence, but what is your tire pressure at?
Old 01-11-2010, 11:59 AM
Yes, they will skip in reverse either direction at any speed. If I reverse very slowly you can see the tires begin to skip and then finally skip. It looks like the tires are binding with something almost as if they are being pushed.
Tires are at 30-35 psi and I first started noticing it a few months ago. That's when I started replacing things and it's only gotten worse.
Another theory for the rear end being the cause. If I'm stopped, and making a turn hard left or right turn, slowly, the rear tires will skip almost like wheel hop then will spin.
Also, I have the latest Kumoho Ecsta XS tires all around and do not like to grip in cold weather.
Old 01-11-2010, 01:07 PM
99MUSTANG5.3L's Avatar
Are the front tires/wheels oversized? Just thinking maybe they're too wide and rubbing on suspension?
Any noises from the rear?
Old 01-11-2010, 03:01 PM
The fronts are 275/40/17 on a 17x9 zr1. No rear end noise. Alignment?
Old 01-11-2010, 03:07 PM
chaman's Avatar
I have a hard time to understand what you mean by skip....It does this at any temp? With cold tires only?
Old 01-11-2010, 03:16 PM
Banned Village Idiot
LS1BLKSS's Avatar
Old 01-11-2010, 03:20 PM
chaman's Avatar
Originally Posted by LS1BLKSS
Im trying to help the guy...what are you offering to this thread, *******? Go look at pics of my car a bit more like you like to do.
Old 01-11-2010, 03:31 PM
LS1BLKSS's Avatar
LOL look at the piece of **** for what??? wanna be camaro boys car 19" FTL!!!
Old 01-11-2010, 03:36 PM
chaman's Avatar
Your obviously looking to start ****. You are reported. You are not even attempting to help the guy....lets see your CRAP car side by side with mine...lets even make a poll...
Lets see it even been consider for any mag coverage...you are a jealous loser. I will try to continue helping the guy, you can continue to be the *******.
Old 01-11-2010, 03:55 PM
LS1BLKSS's Avatar
LOL god your a fucken faget , MODS HELP ME HELP ME!!!!
Old 01-11-2010, 03:59 PM
chaman's Avatar
What you mean with skip is that they drag over the ground when on reverse? get deformed? Cold front tires tend to do that, thats why I asked.
Old 01-11-2010, 04:20 PM
Cold or warm outside. Skip... slide sideways... like front wheel hop going in a backwards motion.
Old 01-11-2010, 04:24 PM
chaman's Avatar
It could be normal though. Ive heard this issue in others and even other car makes. I believe some tires tend to do this more often than others. Have you try getting other tires and see it it continues to happen?
Old 01-11-2010, 04:43 PM
These are about a year old and started a good 8 months after I got them. Could be possible.
Old 01-11-2010, 04:44 PM
chaman's Avatar
Try with another set of tires. Its worth a try! maybe some a friend could lend you for the test. If everything checks out I wouldnt worry about it too much.
Quick Reply: Front tires skip when in reverse
