which clutch for LS1 swap in a Honda S2000
I have a 2000 LS1 in my Honda S2000 which clutch should I go with when I pull the motor to do the painting of the engine bay and car? The motor is stock and will stay that way most likely, should I do a GM LS6 flywheel,clutch,bearing and new slave. I would like to keep the cost around 300-400 if possible.
