are all weld draglites stamped?
I just noticed that the new (used) weld draglites that I bought are only stapmed (weld racing) on the fronts. Are all weld's stamped like that near the stud holes? The backs are not on mine. They look identical but they aren't stamped. 16x8's btw.
Weld Racing used to stamp the mfg date around the bolt circle. They do not stamp these wheels any more. The best way to make sure they are genuine Welds is the floating spacer between the front and rear rim shells. If they are 16x8's then they are an old discontinued Weld wheel called the XP series. The true draglites are only made in 15 inch sizes. Post a pic to make sure.
