stock cluster no pcm
anyone know if this is possible. make the stock 2002 gauge cluster work without the stock pcm. i run bs3 and no longer have the stock pcm or wiring harness. i jus twant the basics, speedo, temps, oil pressure, tach, fuel.
is it possibly, ive searched with no luck
It looks like everything comes from the PCM except the oil pressure and the speedo, heres the pin out for the cluster connector
A1-A2
Not Used
A3
PNK
39
Ignition 1 Voltage
A4
Not Used
A5
TAN/WHT
33
Brake Warning Indicator Control
A6-A7
Not Used
A8
BRN/WHT
419
MIL Control
A9
Not Used
A10
ORN
640
Battery Positive Voltage
A11
Not Used
A12
LT BLU
14
Left Turn Signal Lamps Supply Voltage
A12
LT BLU/WHT
1414
Left Front Turn Signal Switch Signal
A13
PPL/WHT
237
Instrument Panel Lamp Control
A14-A16
Not Used
A17
LT GRN
11
Headlamp High Beam Supply Voltage
B1
BRN
9
Park Lamp Supply Voltage
B2
Not Used
B3
GRY
728
Security Indicator Control
B4
Not Used
B5
PPL/WHT
1035
Starter Relay Coil Supply Voltage
B6
GRY
1036
IPC Class 2 Serial Data
B7
ORN/BLK
737
Trunk Lamp Control
B8
DK GRN/WHT
817
VSS Signal
B9
GRY
8
Instrument Panel Lamp Supply Voltage - 1
B10
DK BLU
15
Right Turn Signal Lamps Supply Voltage - Europe, Japan
B10
DK BLU/WHT
1415
Right Front Turn Signal Switch Signal - Domestic, Gulf
B11
BLK
650
Ground
B12-B22
Not Used
B14
TAN
31
Oil Pressure Indicator Control
B15
BLK
650
Ground
B16-B17
Not Used
A1-A2
Not Used
A3
PNK
39
Ignition 1 Voltage
A4
Not Used
A5
TAN/WHT
33
A6-A7
Not Used
A8
BRN/WHT
419
MIL Control
A9
Not Used
A10
ORN
640
A11
Not Used
A12
LT BLU
14
A12
LT BLU/WHT
1414
A13
PPL/WHT
237
A14-A16
Not Used
A17
LT GRN
11
B1
BRN
9
B2
Not Used
B3
GRY
728
B4
Not Used
B5
PPL/WHT
1035
B6
GRY
1036
B7
ORN/BLK
737
Trunk Lamp Control
B8
DK GRN/WHT
817
VSS Signal
B9
GRY
8
B10
DK BLU
15
B10
DK BLU/WHT
1415
B11
BLK
650
Ground
B12-B22
Not Used
B14
TAN
31
B15
BLK
650
Ground
B16-B17
Not Used
