What to do now?
Old 01-14-2010, 09:15 PM
dwfronk's Avatar
Default What to do now?
My rear end is going bad. I know it is time to up grade so my question is do i rebuild the stock. or upgrade to a new one. And if i upgrade what should i go with. I have been looking at the moser 12 bolt. i am going to be doing this on a tight budget.
another thing i dont know much about rear ends so bare with me.
Old 01-14-2010, 09:20 PM
Lanaue's Avatar
what are your mods? If you can get a better rear get one.someone had one on craigslist with 410 gears for $1,800.
Old 01-14-2010, 09:34 PM
dwfronk's Avatar
I have swapped a LQ4 into the car not to long ago but it is a stock bottom end with 5.3 heads and long tubes. I did enough to get the car running when i blew the factory block and i plan on a good set of heads and cam at some point. The car is and 01 with T56 and Ram power grip HD clutch. Its not too extreme but i want something that is going to hold up to what i have now and what i add later on.
Old 01-15-2010, 04:58 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com...html?item=2227
The above link may help answer some of your questions. Bob
