ls1 nitrous help
ls1 nitrous help
ok i just got a zex dry nitrous kit and ive got 75 and 100 shot jets and its a stock motor with mild mods and need to know what other changes i need to make like do i change to a diferent plug or do i adjust timing and how on a 99 ls1 camaro
Nick
Guest
Posts: n/a
Everyones idea of mild to wild is different, but if you don't have a cam or anything like that then you should be able to spray the 75-100hp shot without a problem. You will need to change the plugs in the car and I'd suggest going to a NGK BR7EF stock# 3346. Other than changing the plugs with a dry system you need to make sure you have enough fueling to cover the nitrous as well as injector because with a dry kit you are relying on the fuel pump and injectors to compensate for fueling. For the timing aspect of it we have had phenomenal results with the Lingenfelter unit http://www.nitrousoutlet.com/catalog...1&product=3467 .
ok so switched to a wet kit and its 100 shot but still zex kit so i use a 4n line from the fuel rail to the module and hook the bottle to the module run 3n lines from the module to the nitrous port and hook up the tps wire power and ground and pull 4 degrees of timing then change plugs. do i still use the ngk br7ef part #3346 listed above or do i need to use a different one for a wet kit ?and thank you for all the help guys.
