heads for boost
Old 01-15-2010, 02:45 PM
1bad99's Avatar
Default heads for boost
would the 317 6.0 LQ4 heads be a good head for boost
Old 01-15-2010, 02:56 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
That really depends on the entire combo. Alot of guys do run those heads on stock short-block LS1's to lower the compression some for a bit of boost. On a forged short-block, which'll be needed for anything serious boost wise, you'd be better off with the LS6's heads or an aftermarket casting head and the appropriate piston/gasket to get the compression where you want it!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 01-15-2010, 06:04 PM
Banned Village Idiot LS1BLKSS
BLK:UFO's Avatar
for a stock block 317's are good
Old 01-16-2010, 07:08 AM
1bad99's Avatar
if i go with the 317's and a good cam with a tune should a get a good gain in power.
Old 01-18-2010, 09:42 AM
jason00ss's Avatar
depends on what block you are using. i plan on doing a lq block and using the l92 heads as they require a 4" bore. but if using the ls1 block, 317's are a very popular head for fi
