Pics of under body with the use of bmr extreme torque arm!
I would like to see how this is mounted on the car, if your car is on a rack, even better. This thing looks like it hangs so low to the ground its unreal. I would like to see how low it is to the ground and how u welded it to the frame connectors?
thanks in advance, Tom
here is the link to BMR's website. look at the pictures of the installed trak-pak torque arm. it is the same size as the extreme duty torque arm so all mounting is exactly the same. that should help you out some.
http://www.bmrfabrication.com/F-bodySuspension.htm
Yea I have seen those pics but they do NO justice at all. I need to see other peoples cars and see how low this actually is on the car when on the ground. Also where exactly they mount this on the frame connector. But the big concern is how low to the ground is it, especially where the loop is where it clears the driveshaft? So anyone with pics please post them.
Hell, will it even allow you to run that setup on a lowered car?
thanks, Tom
thanks, Tom
thanks, Tom
thanks, Tom
